Please Help
Old Feb 21, 2004 | 12:00 PM
rblair's Avatar
Please Help
i am having trouble with getting trouble codes out of my comp. with the scan tool that i have. when i plug it into the aldl connector the service engine light will come on but i don't get any flashes at all. it won't even flash the 12 code. does anyone know what i need to do to get the tool to read the codes? I am having ignition problems when the motor starts and runs for 2 or 3 minutes and start missing and backfiring throught the exhaust. then it will quit and when you try to restart it there is no fire to the plugs or the coil. I can't get any fire anywhere until it cools off then it will start right back up and do the same thing again.
Old Feb 21, 2004 | 12:36 PM
ead94z28's Avatar
You did not specify the year, but if it's an OBDII car and you are trying to use a autoparts store scanning device it won't work. Get something specific for that year car.
