Please help!
Old Sep 14, 2003 | 11:24 PM
fozziez28's Avatar
Angry Please help!
Car is dying at the stoplights. Engine runs smooth, but the car is just dying on me at lower rpms. i just replaced the opti two days ago? Anyone got any ideas. I am also getting a ses light. I am gonna try to get it scanned to figure out what it is. Thanks, Michael
Old Sep 14, 2003 | 11:26 PM
scoobysnax83's Avatar
sounds like you may have a leak after the MAF and before the TB. Check the elbow and make sure you have it on correctly. Does it do it in neutral?
Old Sep 14, 2003 | 11:31 PM
InjectedSS's Avatar
sounds like a vacum leak to me... check all your vacum hoses at your throttle body and on your intake...
Old Sep 14, 2003 | 11:36 PM
...and a stuck open EGR valve is like a big vacuum leak. Check it, too.
Old Sep 14, 2003 | 11:38 PM
fozziez28's Avatar
I am not sure if it does it in nuetral. I havent driven it since this morning, because I am afraid I wont make it back home. I am pretty sure the elbow is one correct. I ran my finger underneath it to make sure it was on and not bent or anything. I took it in like two weeks ago and i had them check for codes and I got a code 048 which they said was a maf code. The engine runs to smoothly for the maf to be bad. It runs like a brand new engine, other than the constant dying. I am unsure of the vacuum tubes you are talking about, and what should I be looking for. Thanks, Michael
Old Sep 14, 2003 | 11:39 PM
Very true. A friend of mine has a faulty EGR that is progressively getting worse. His car feels like it wants to die under part throttle and at idle. Definitely likely...
Old Sep 14, 2003 | 11:40 PM
fozziez28's Avatar
where is the egr valve? I'll check that out too.
Old Sep 15, 2003 | 12:07 AM
My Tech Page has all kinds of pics of component locations.
