please educate me on camshaft basics
Old May 27, 2005 | 03:35 PM
97HUGGER's Avatar
Is there such a thing as having too much lift on a camshaft and are there any negative effects on performance by having a high lift cam on a mildly ported head. Do the flow numbers of the head need to be matched to the lift of the camshaft. I am looking at installing a camshaft with .560/582 lift on a head that flows approx 245 @.500 and 250 @.600 is this too much lift for the cylinder heads? Also will a stock LT1 motor have any clearance issues with that high a lift. Thanks
Old May 27, 2005 | 04:43 PM
BUBBA's Avatar
Re: please educate me on camshaft basics
There is such a thing as not enough room between the piston at TDC and Exhaust valve which if not adequate might wind up in a collision between the two resulting in a rebuild. Or maybe I'm just full of it today.
Might be advisable to clay the pistons before yougo too far.
Old May 27, 2005 | 05:50 PM
mastrdrver's Avatar
Good read in the Adv Tech section
Hotcam: Advanced look
Old May 27, 2005 | 08:33 PM
1racerdude's Avatar
The cam's duration and lift should be matched to the flow numbers. The intake CL should be matched to your intended use generally a +4*
David Dempsey
Mar 12, 2016 12:42 AM
football4life
Oct 4, 2015 07:48 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
Daluchman1974
Sep 11, 2015 06:12 AM
