Play in the driveshaft...Is this normal?
Old Sep 30, 2003 | 06:15 PM
drewstealth's Avatar
Well i was under my car last night trying to figure out where the noise in my transmission is comeing from. For instance if i push on and off the gas in 3rd gear real fast it sounds like my transmission is very loose and something is banging back and forth inside it. So when i was under the car i shook the driveshaft up and down. I was able to move it up and down a little bit. Is this normal? Also when i put the car in neutral and spun the driveshaft by hand i can hear weird noises rattleing sound comeing from the tranny. I'm thinking that maybe my driveshaft is messed up. What do you think.
Old Sep 30, 2003 | 06:18 PM
Rodrigues's Avatar
Did you check your transmission mount?
Old Sep 30, 2003 | 06:45 PM
96 WS6's Avatar
Up and down? I mean the DS is splined into the tranny, so if there is play it is probably the U Joints... The loud noise is usually associated with a bad tranny mount though. Check both out.
Old Sep 30, 2003 | 10:03 PM
Got-LT1's Avatar
That's often a sign of worn U-joints.
Old Oct 1, 2003 | 02:13 AM
I have a ES Tranny mount already. I looked at it also seems fine. I don't know what else it can be. But if i press on the gas and let off real fast i can here the noise. It sounds like the transmission is rocking back and forth or something.
Old Oct 1, 2003 | 02:23 AM
SiDeWaYZz28's Avatar
sucks to hear you are haveing tranny problems man hope you get it figured out i cant help you i dont know much bout m6 . . i was wondering what color is your maro??maybe ill see you around town . . where do folks meeting up to race you know??
Old Oct 1, 2003 | 02:42 AM
My Camaro is Green. You probably won't see it to often during the day since i work in Vallejo from 8-6pm 6 days a week. Its on the stock rims for now. I will pm you with some more info though.
Old Oct 1, 2003 | 02:53 AM
what part of town you stay in i live off waterman blvd on the west
Old Oct 1, 2003 | 02:29 PM
rudeone707's Avatar
Here is a post from one of my friends on a dif site.
Originally Posted by matm347
This sounds like it may be two things, one is his throw out bearing, the rattle when the car is in neutral, I bet it goes away when he hits the clutch, he needs to adjust his clutch.
The clanking and play in his driveshaft seems to be a bad U joint, put the car in 1st and drive while hitting the throttle, like you are punking someone, It should re create the noise, if so, U joints are pretty cheap.
Hope i helped in any way.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
