Plastic LT1 fuel lines
Old Oct 9, 2016 | 10:17 PM
ZZ's Avatar
ZZ
My 97 fell victim to a critter gnawing a small hole in my fuel line right below the driver side rocker. They chewed the nylon tubing. I can't find the OEM lines available anywhere, so what options do I have. Is there a way to splice these reliably? Anyone know what size these lines are if I can? There's a few lines running there, but it looks like only one got damaged. Thanks.
Old Oct 9, 2016 | 11:30 PM
Re: Plastic LT1 fuel lines
Shoebox has the part number for the 3-line bundle. Is that what you are unable to find? Thought it was still available, maybe 6 months ago.
10258441
Supply line is 3/8", return line is 5/16". Not sure about the EVAP purge line.
1993-1997 F-Body Part Number Collection
There are compression fittings that attach to the metal lines under the rocker and at the rails, so you can use braided SS lines. I believe I've also seen a thread somewhere here that someone had a shop make new lines using high pressure fuel hose. Note however that NHRA limits the length of rubber fuel hose in the system, if you run at an NHRA track.
Old Oct 10, 2016 | 12:08 AM
ZZ's Avatar
ZZ
Thanks for the reply Fred. I did find the part number on Shoebox's page, but everywhere I try to find it, it comes up discontinued.
Old Oct 10, 2016 | 01:40 AM
Fatdog2's Avatar
O'Reilly auto parts store has some fuel line connector barbs for plastic fuel lines.About $7.00 or so.Hope this helps.
Old Oct 10, 2016 | 10:51 AM
Did you try these:
#10258441: PIPE. Fuel Line
Buy GM 10258441 Pipe, genuine OEM part
If you call Nalley and they don't have the part (shows discontinued), they may be able to do a search to find a dealer that still has it in stock.
PIPE. Fuel Line for Chevrolet Camaro (1994 - 1997). #10258441
Old Oct 10, 2016 | 12:20 PM
ZZ's Avatar
ZZ
Thanks again Fred. Yo da man! I was trying gmpartsdirect and a couple others. Also, thanks again for keeping this site going and offering your knowledge and experience to folks to keep this forum going. It is very much appreciated.
Fossil Rock
Jul 18, 2016 04:49 PM
horridohutch
May 31, 2016 11:17 PM
dkred94z
Parts Wanted
Nov 5, 2015 07:21 PM
v6maro
Sep 5, 2002 08:36 AM
Espo
Aug 13, 2002 01:40 AM
