Pitting around water jackets
Old Jun 4, 2012 | 01:43 AM
ascastil's Avatar
Supposed to get my head gaskets shipped Monday. I cleaned up the block free of any old gasket material. Around the holes where the large coolant passages are there is some corrosion. It never leaked before and I could see where the previous gasket had sealed up around the passage so it didnt leak. Should I be worried about this in the future? The block had been rubuilt about 2 years ago, bearings, new pistons, bored, reused the crank and the rods. The deck was only cleaned up,but I dont recall the coolant holes looking like this, I hope its just normal. Like I said, it wasnt an issue before, I would assume a little wear is normal aroun those coolant passages, I hope.
Old Jun 4, 2012 | 05:18 AM
RamAir95TA's Avatar
Re: Pitting around water jackets
Post pics of the corrosion/pitting.
Old Jun 4, 2012 | 07:51 AM
ascastil's Avatar
[IMG][/IMG]
Old Jun 4, 2012 | 10:32 AM
RamAir95TA's Avatar
A MUCH higher resolution picture would be more beneficial. Can't really see much there...
Old Jun 4, 2012 | 11:05 AM
ascastil's Avatar
Hope these are better, thats about as good as I can get unfortunately.
Old Jun 4, 2012 | 07:50 PM
ACE1252's Avatar
That's interesting....I don't recall seeing that on my block last time I had it apart. What coolant are you using? Using any additives in it? Did you use distilled water to mix with the coolant(or did you buy premixed coolant)?
Old Jun 4, 2012 | 08:00 PM
Dave89IROC's Avatar
Not uncommon, the ports in the head don't cover there, so coolant always sits there, but I agree with the above, what coolant are you using?
Old Jun 4, 2012 | 08:48 PM
ascastil's Avatar
Just some premixed coolant. Also a little off topic, got my head gaskets in today and of course the coating on them peeled off when I was taking them out of the package. Darn. Gonna send them back and get the Victor Reinz ones instead. I talked to someone and they said they arent packaged as tightly.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
