Which pistons should I choose?
Old Jul 6, 2004 | 07:55 PM
TransAm-Z's Avatar
I'm tring to decide between the speed-pro power forged piston(10.4 CR) or K.B. hypereutectic (10.9 CR).
I don't plan on running NOx or a supercharger, but I want a piston that will handle my foot. For now I will be running the HOT cam with stock heads and stock manifold. So will the K.B piston be fine for this application? Or if I did go with the heavier forged pistons, will they hurt my performance being heavier?
Old Jul 7, 2004 | 10:05 AM
arnie's Avatar
Hypereutectic not recommended, not durable enuf. Weight issue is mute point, when 'minimum durability requirement' takes precedent.
Old Jul 7, 2004 | 10:15 AM
Don 97 SS's Avatar
I am no expert engine builder, but I would only consider a forged piston for a rebuild of a performance engine. It is JMHO, but hyper and cast pistons are fine for grocery getters and such, but just not my cup of tea for any performance engine. I'd only recommend a hyper if you are on a tight budget.
Old Jul 7, 2004 | 10:22 AM
Mindgame's Avatar
Had over 100 passes on a set of KB hypers before refreshing a 353 ci bracket racer here two years ago. Shifting at 7900 rpm and coming through the traps at just over 8 grand.
Other than a bit of pin bore elongation (I've seen similar from forgings) the KB's did their job, then some. No excessive scuffing, no signs of cracks, money well spent. If going NA, they are a really nice piston to use if you're looking to save some money. No sacrafice in durability as far as I'm concerned.
-Mindgame
Old Jul 7, 2004 | 04:05 PM
TransAm-Z's Avatar
I've heard that the Hypereutectic pistons are fine for N/A motors under 450 HP. Has anone that says to stay away from them, actually run them and had bad experiences? Or is it more on hear-say? I'm not tring to tick anybody off, just want to make sure there is some backing behind it. Right now the extra money for forged pistons is not the issue, but I am not building a $6000 motor either...
Old Jul 7, 2004 | 05:11 PM
arnie's Avatar
My error. I understod/answered as if you WERE planning on FI. My comments apply to the extra power sources you stated you were NOT using, as KB would agree with.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
