Pistons?
Old Oct 26, 2009 | 05:51 PM
JohnnyRage's Avatar
Pistons?
Hay guys!! Real quick I'm going to start to rebuild my motor I'm looking to keep it simple may be cam and heads do I replace the pistons or reuse. The rebuild kit can come with Forged Flat or Hypereuectic I red some place an LT1 comes with hypereuectic pistons and I drive my car hard my baby has 189245 miles on her so when do you re place pistons? You guys know better then me THANKS !!!!!
Old Oct 26, 2009 | 05:55 PM
ulakovic22's Avatar
Upgrading to forged pistons is always a good idea if the budget allows. Do you plan on anything else other than H/C?
Old Oct 26, 2009 | 06:28 PM
JohnnyRage's Avatar
I might spray it like a 75/ 100 shot but i don't know
Old Oct 26, 2009 | 08:05 PM
green96ta's Avatar
Easy
that's a no brainer. If you have the cash go forged. ESP if your going to be spraying.
Old Oct 27, 2009 | 05:10 PM
JohnnyRage's Avatar
OK cool thanks a lot
Old Oct 27, 2009 | 05:31 PM
96capricemgr's Avatar
If you have the cash Mahle forged pistons would be my choice, the other ideas are for if you are trying to save your pennies.
If the block does not need boring I might just inspect and reuse the stock pistons. Most inexpensive replacement pistons are going to be a step backwards in the ring pack and the stock motor will take 150 shot very reliably so long as the tune is right.
At that mileage though pistons might be worn and I might also consider just a low mileage b-body shortblock. Should be able to get one for $500 and it will cost a lot more than that to rebuild your's to comparable quality.
Old Oct 27, 2009 | 05:33 PM
green96ta's Avatar
oh you just say that cause you drive a b-body
all joking aside, i contemplated that very idea when i spun my rod bearing...
Old Oct 27, 2009 | 09:22 PM
JohnnyRage's Avatar
I'll just go for broke and get forged and do it right the first time
Old Oct 28, 2009 | 12:37 AM
Sleepy_Z's Avatar
Hey Johnny
I'm in the same boat. I'll be going with forged pistons with a rebuild kit from summit. Trying to stay as low budget as I can. So I'm looking to reuse the stock rods. I won't buy anything till engine gets torn apart to see what's really needed. Like what was mentioned already about bore size. I'm still debating to try and tackle this myself or pay someone to do it. Since it's gonna be a very long winter up here.
Old Oct 28, 2009 | 12:36 PM
Just to be clear, a b-body shortblock is the same, just less likely to have been abused and generally cheaper.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
