Piston to valve clearance with this cam?
Old May 11, 2003 | 11:22 AM
jimbo95Z28's Avatar
Exclamation Piston to valve clearance with this cam?
Just wondering if any of you would be able to help me on this. I have a cam that the specs are as follows: 234/241, 576/595 on a 111.8 LSA. I was wondering with that lift and 2.0/1.56 valves do you think that I would have piston to valve clearance problems if I milled the heads .020 with a .039 head gasket? I really want to get a bit more compression out of it, but I don't want to have to rebuild while I am at it. The pistons are stock type .040 over with valve reliefs. Please let me know if you have any insight. Thanks.
Aaron
Old May 12, 2003 | 12:37 AM
jimbo95Z28's Avatar
ttt
Old May 13, 2003 | 06:05 AM
HungryT/A's Avatar
I don't think you'd have any piston-valve clearance probs. Anything below .650" lift is fine.
But let's have some more input on this for ya!
Old May 13, 2003 | 12:04 PM
Dr.Mudge's Avatar
I dont think you will, but with .020" taken off the head you are probably getting close. I would mock it up with clay to find out before you go based on anyones word.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
