Piston Rings
Old Aug 7, 2008 | 05:55 PM
My Red 93Z-28's Avatar
Piston Rings
I'm wondering what are some good piston rings for the 355 listed in sig.
Old Aug 7, 2008 | 06:25 PM
96capricemgr's Avatar
How do you expect anyone to answer without telling us what the pistons are??
Old Aug 7, 2008 | 06:37 PM
RACEON's Avatar
Call the manufacturer of the pistons and use theirs. Dont use low tension, unless you like to make ARABS richer!
Old Aug 7, 2008 | 07:05 PM
4.030 Forged TRW pistons
Old Aug 7, 2008 | 08:20 PM
Without checking TRW's catalogue I am not sure if they offer pistons that take one size ring or if they also offer pistons for thin rings.
I will say it was a mistake if you bought old school pistons for thick rings, part of why the LT1 works so well is the thin low drag rings.
Old Aug 7, 2008 | 08:25 PM
The pistons were part of the LT1 rebuild kit that Summit sells
Old Aug 8, 2008 | 09:38 AM
seawolf06's Avatar
Any rebuild kit parts are going to be lower quality, but you will probably ok if you are just looking for a street car and not a racer.
Find the kit on summit and see what size rings you need for those pistons. You can buy pre-gapped rings or file-to-fit. If you're planning on any power adder or a lot more HP than stock, you should get the file-to-fit and have someone who knows what they're doing install them for you.
Old Aug 8, 2008 | 10:43 AM
No power adders, just NA. I have the LT4 conversion but the heads aren't ported, so not a big hp increase.
Old Aug 8, 2008 | 10:54 AM
seawolf06's Avatar
You'd probably be ok with some perfect circle or total seal rings. You just have to make sure they match your pistons and come pre-gapped.
Old Aug 8, 2008 | 11:52 AM
File fit isn't a problem if I have to get those, I believe we had to do that last time anyway. Thanks for the responses
magman
Apr 15, 2016 03:08 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
