Piston Rings
Old May 25, 2004 | 10:09 PM
Mystic97Z's Avatar
Piston Rings
i'm going to be replacing the rings later this week, should i get new factory replacements? or is there an aftermarket piston ring that would HELP performance?
Old May 26, 2004 | 03:00 PM
Mindgame's Avatar
Sure, the Speed Pro moly rings are ~$69, cast are ~$50. Check with Scoggin Dickey.
I'd go with the moly ring set myself but either would work fine.
-Mindgame
Old May 26, 2004 | 03:20 PM
TexasTechTA's Avatar
why do you need new rings on your car anyway? spray?
Old May 26, 2004 | 03:31 PM
Mystic97Z's Avatar
na, i just pulled the engine out for a head/cam install, and while i'm there i'm gonna put some in.
Old May 26, 2004 | 05:23 PM
H/C LS6Z's Avatar
o ok
Old May 26, 2004 | 09:09 PM
kyzar24's Avatar
you want to put cast rings only on stock pistons
magman
Apr 15, 2016 03:08 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
