piston question?
Old Jun 15, 2003 | 12:52 PM
StreamlineZ28's Avatar
piston question?
can you get a domed piston with valve refiefs.
Old Jun 15, 2003 | 02:05 PM
InjectedSS's Avatar
yes you can i believe almost all pistons come with valve reliefs
here look at
THIS PIC
now the piston on the top left is an inverted dome piston with valve reliefs
the piston on the top right is a DOME piston with valve reliefs
the piston on the bottom is a flat top piston
Old Jun 15, 2003 | 02:11 PM
Dave88LX's Avatar
Yep, but what are your plans?
If you take even a -5cc flat top .005 out of the hole with a .039" head gasket with stock chambered 54cc heads, you're going to be running ~12.7:1 CR...
Old Jun 15, 2003 | 07:30 PM
the Afr 210 Lt4 heads are a 76 cc combustion chamber
Old Jun 15, 2003 | 07:40 PM
Dave88LX's Avatar
Oh Well that's quite a difference
Old Jun 15, 2003 | 10:09 PM
rskrause's Avatar
Moderator
If you are buying new AFR heads, they can be supplied with chambers down to 56cc, if remember right. A smaller CC with a flat top (or dish) is the better way to get high compression. The dome interferes with travel of the flame front,
Rich Krause
Old Jun 16, 2003 | 09:46 AM
maybe i'll email them cause in there catalog it says only 76cc for the 210 lt4 head, you can get the 195 lt4 head anywhere from 56-74cc's but i doesnt say the 210
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
Dmonty
Jun 2, 2015 11:19 PM
1963SS
Feb 6, 2015 10:05 AM
