piston direction
Old Jan 21, 2006 | 04:56 PM
ppa95z28's Avatar
piston direction
hey all i have a question. i took out my pistons and am now reassembling the motor. the pistons are marked with a b and an arrow pointing in a direction. does this arrow point towards the back of the motor...... or should i stick with the manual and point the arrow towards the front.
d. by the way the notch that holds the rod bearing is on the right of the rod if you were to look from the piston down to the rod bearing and the arrow is pointing to the right. hope this helps. also the two dots and the cuts into the rod next to the cap bolts are facing the right too. please help.
Old Jan 21, 2006 | 05:33 PM
MachinistOne's Avatar
Re: piston direction
The arrow goes to the front of the motor for reasons of pin offset.
The tang on the bearing is different on some motors, chevy, ford, chry...what you look for is the chamfered side of the rod which goes outboard of the two rods that are side by side...
/__| |__\ <-- like that. So that the bearing does not ride up the radius on the crank journal.
Old Jan 21, 2006 | 07:00 PM
1racerdude's Avatar
When ya install the piston with the arrow pointing forward the brg tabs are on the ground side of the crank(down pointed away from the cam) with the crank down on the stand.The tabs in the cap and the tabs in the rod are together on the same side(down). The chamfers have to face the left or right of the center of the rod journal as M1 said.
Old Jan 22, 2006 | 03:19 AM
wrd1972's Avatar
Up and down
Sorry I could not resist.
Werd.
Old Jan 22, 2006 | 08:12 AM
ppa95z28's Avatar
damn i forgot they went up and down. i could have sworn the lt1 was a rotary engine. thanks for clarifying. lol
Old Jan 22, 2006 | 08:56 AM
wrd1972's Avatar
Thanks for being a good sport, I was really needing a good laugh at the time.
Old Jan 23, 2006 | 12:36 PM
ppa95z28's Avatar
i dont mind having a little fun. i dont take anything personal on forums... its just a waste of time. but i liked your reply it made me laugh.
Relaquary
Jul 6, 2015 09:42 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
1963SS
Feb 6, 2015 10:05 AM
