piston bore?
Old Apr 7, 2008 | 09:33 AM
Austin_78@msn.com's Avatar
piston bore?
can anyone tell me what the stock bore on the z28 is for the 1993
Old Apr 7, 2008 | 09:35 AM
jasonface's Avatar
4.0" bore x 3.48" stroke
cvccbum's Avatar
4 = bore
3.48 = stroke
Old Apr 7, 2008 | 11:47 AM
honing
now im not sure this question fits this forum, but is honeing the cylinders just cleaning them, them boreing them is when of course you increase the cylinder size?
Old Apr 7, 2008 | 11:59 AM
RUDEDOG's Avatar
Cylinders are bored and then honed to final size.
Old Apr 8, 2008 | 12:04 AM
so if you are honing the rust out of your cylinders then your cleaning them without the bore or with it???
Old Apr 8, 2008 | 12:08 AM
MachinistOne's Avatar
For a cylinder cleanup you would just hone the cylinder, if the motor needs to be rebuilt and you are going .030 over you would bore, then hone.
Old Apr 8, 2008 | 12:13 AM
ok thats what i thought!
but i just had to make sure...
thanks
Old Apr 8, 2008 | 04:42 AM
rskrause's Avatar
Moderator
Yes, but honing does remove some metal and thus will slightly increase the bore.
Rich
Old Apr 8, 2008 | 03:19 PM
so should i buy forged or regular stock pistons???
if i buy the regular sized ones, will this screw up my compression or anything?
Old Apr 8, 2008 | 06:56 PM
maverickmk's Avatar
are you boring or honing? if you have rust, I would think you will need to bore it out some - if you aren't going to go to radical then stock-type pistons would be fine - check out this site for more info:
http://kb-silvolite.com/article.php?action=read&A_id=5
Old Apr 9, 2008 | 12:04 AM
i am just honing surface rust out and wated to know if the stock pistons if i am buying will fit and not mess anything up.
Old Apr 9, 2008 | 05:07 AM
rskrause's Avatar
Moderator
They will probably be ok. Only way to tell for sure is to take measurements.
Rich
Old Apr 9, 2008 | 08:54 AM
ok then
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
heus
Sep 8, 2015 12:01 PM
