picture of waterpump anyone?
Old Sep 19, 2004 | 11:43 AM
  #16
Jeffs94Z28's Avatar
Re: picture of waterpump anyone?
Thanks, you guys are a big help.
Old Sep 19, 2004 | 11:49 AM
  #17
Jeffs94Z28's Avatar
Z95, I have hooker long tubes so there is no hole to block, and I have the hole blocked my CAI too. But for some reason the mechanic didn't remove the air pump.....what is the purpose of the air pump anyways? Just emissions?
Old Sep 19, 2004 | 12:02 PM
  #18
Z95m6's Avatar
It is an emissions device but you don't need it. The pump only runs for the first few mins when you start the car and then shuts off. So you only need it for visual inspections. The 93-95's maybe 96's included have a recall because they always go out so they replace them with a better one. Mine was blowing the fuse all the time and setting off the SES light so i just took it off, but if you just unplug the air pump and take it off you won't get the SES light.
Old Sep 19, 2004 | 02:25 PM
  #19
1995no41's Avatar
(new member- just happen to be doing a water pump for the first time today and jumped in here)
So if I may ask- the AIR pump will not affect anything ( like throwing a code or tanking my mileage?). From the latter of these posts, it looks like you guys say it can be removed for a cleaner look. True?
Also, I've got a post concerning my own coolant leak problems-look for the one at 2:00 more or less today; I'd love to have anyone's advice I can. First real project on the LT1 for me.
Thanks, all.
Old Sep 19, 2004 | 02:53 PM
  #20
Spinner's Avatar
Thanks, all.
Yep, pull it out.
Old Sep 19, 2004 | 05:14 PM
  #21
Mtrhds94Z's Avatar
The AIR pump recall was for 95-7
See:
http://web.archive.org/web/200104190...egg/99083.html
Old Sep 19, 2004 | 05:21 PM
  #22
Z95m6's Avatar
See:
Sorry about the misinformation. I remembered it included 95 as my car was eligible for it. Ususally its the first years that cars come out the problems a rise thats why i figured it was 93-95. Sorry about that.
Old Sep 19, 2004 | 10:58 PM
  #23
Jeffs94Z28's Avatar
I took out the airpump today, and most of the bolts holding its metal bracket on, except for one, its on the bottom left side of the bracket, it just wont budge. If I push hard on the wrench and socket (I tried both) it just slips off, and its starting to get stripped. Is this bolt reverse threaded? I'm buying a compressor/air rachet tomorrow to see if it'll do the job.
Old Sep 19, 2004 | 11:00 PM
  #24
No reverse threads. Use a 6 point socket.
Old Sep 19, 2004 | 11:09 PM
  #25
Jeffs94Z28's Avatar
haha wow, you post quick. Thanks man, by the way what size is the 6 point socket I should get?
Old Sep 20, 2004 | 12:18 AM
  #26
Jeffs94Z28's Avatar
Another question, I have hooker long tubes, with a highflow cat and a flowmaster muffler. I have the cai plugged off and the hookers have no emissions holes. If I remove the airpump will it make any difference in passing emissions? Im just curious, because if the headers alone will keep me from passing I'll just go ahead and remove it.
Old Sep 20, 2004 | 12:21 AM
  #27
96speed's Avatar
http://memimage.cardomain.net/member...76_67_full.jpg
Ryan
Old Sep 20, 2004 | 01:50 AM
  #28
Jeffs94Z28's Avatar
my mouth waters when i see that, but what size socket takes off the bolts for the air pump bracket? Because either im using the correct socket already and the bolt is stripped (by a mechanic who installed the water pump). or I need a different size. The socket took the others off just fine.
Old Sep 20, 2004 | 08:15 AM
  #29
I had to go look on my cam removal page. AIR pump bracket bolts are 9/16" head size.
Old Sep 20, 2004 | 08:34 AM
  #30
Jeffs94Z28's Avatar
thanks shoebox
jwade88
Jun 14, 2015 09:38 PM
1970judge
Cars Wanted
May 23, 2015 11:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
