picture of waterpump anyone?
Old Sep 18, 2004 | 04:50 PM
Jeffs94Z28's Avatar
I'm looking for a picture of the lt1 water pump removed, so I can find the last bolt to remove it. Thanks
Old Sep 18, 2004 | 06:06 PM
30696bird's Avatar
Re: picture of waterpump anyone?
there are 6 bolts.................three on each side here is an ebay link for you to see http://cgi.ebay.com/ebaymotors/ws/eB...category=33604 Hope this helps.
Old Sep 18, 2004 | 09:41 PM
I bet it is the RH middle bolt that is slightly behind the power steering pulley.
Old Sep 18, 2004 | 11:08 PM
Jeffs94Z28's Avatar
nah, it isnt. that was a bitch to get out though.
Old Sep 18, 2004 | 11:16 PM
Jeffs94Z28's Avatar
I look in my Haynes manual and I can only find a picture for the bolts on a v6 water pump... and theres like 9 on it..
Old Sep 19, 2004 | 12:05 AM
Fux0redImages's Avatar
I bet it's the bolt that's holding on the air pump bracket.
Old Sep 19, 2004 | 01:01 AM
Jeffs94Z28's Avatar
I believe your right, the install guide im using doesnt have a good pic of the air pump uninstall. where is it? anyone have pics?
Old Sep 19, 2004 | 07:49 AM
It is a stud that the AIR pump bracket slips over. You can se it in this pic, just above and to the right of the upper circled bolt holding on the AIR pump.
Old Sep 19, 2004 | 10:57 AM
Jeffs94Z28's Avatar
Hmm, I got that one off, its a little nut on it isnt it? If I have 4 long bolts, one shorter bolt (from the Passenger side, next to belt tensioner) and the nut off you pointed out, is everything off of it and its just stuck on there a little?
Old Sep 19, 2004 | 11:07 AM
Dave89IROC's Avatar
you have to take out the stud the nut goes on
it is a bolt with a stud out the top
Old Sep 19, 2004 | 11:08 AM
Jeffs94Z28's Avatar
how do you pull it out? plyers?
Old Sep 19, 2004 | 11:13 AM
Dave89IROC's Avatar
pull the AIR pump off and it is a bolt
the pic shoebox posted shows the AIR pump bolts
Old Sep 19, 2004 | 11:31 AM
Jeffs94Z28's Avatar
I'm pretty new to working on this car, the air pump is the black circular container?
Old Sep 19, 2004 | 11:42 AM
RamAir95TA's Avatar
Yes. There are three smaller bolts (10mm I think...) that hold the AIR pump to the bracket, then 2 bolts that hold the bracket to the block, not including the stud. Remove the AIR pump, then unbolt the bracket and slide it off the stud. You'll be able to remove the stud, which doubles as the middle right side bolt for the water pump.
Old Sep 19, 2004 | 11:43 AM
Z95m6's Avatar
Yes its the "Black circular container" Its in shoebox's picture. The part that has the hole running into it. If i was you i would try to get some plugs for your exhaust manifolds and pull the air pump, and mounting bracket off. It really cleans up the engine bay and it makes it quicker/easier to pull your waterpump off if you ever need to.
