Picture of Oil pump with Pick, Need to see how the pickup goes on
Old May 21, 2004 | 10:48 AM
ZDriver96's Avatar
I got my new GM pump, GM white spring, and steel pick up...anyone have a picture so i can see how the pick up goes on... Mine is at the machine shop... good 45minute drive so i wanted to see if anyone had some pics of it.
Also how do u change the Spring? Just unbolt the 4 bolts on teh side of the pump and put in the new one???
Old May 21, 2004 | 11:11 AM
Red96Lt1's Avatar
Don't know about the spring, but I can help you with the pick up orientation. The screen is perpendicular to the shaft. Or parallel to the bottom of the pump. When you put it on, It doesn't look like the pick up does that much.
Old May 21, 2004 | 12:08 PM
Ricardo's Avatar
If I remember correctly, you have to remove a small pin that holds the spring in place. You do this with a small pin punch.
Old May 21, 2004 | 12:22 PM
My pickup was angled down. It was ~5¼" from the mounting surface of the pump to the bottom most part of the pickup.
Old May 21, 2004 | 12:31 PM
brandboZ28's Avatar
The way I "fit" mine was to take a pice of cardboard and cut it to fit in the bottom of the oil pan. Then put the oil pump in and slightly press the pickup tube into the pump where you can still move it but it will stay in place. Test fit the oil pan with the cardboard in the bottom and the pickup tube should slide ito its proper installed hieght. I was told that you want the screen about 1/4 to 1/2 inch from the bottom of the pan. Mark both the pump housing and pickup tube before removing the pump and then take it and have the tube welded to the housing. Hope this helps.
Old May 21, 2004 | 02:47 PM
ZDriver96's Avatar
yes it does....
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
