Pics og my 355Lt1 to 383LT1 swap :D
Pics of my 355Lt1 to 383LT1 swap :D
I traded my 355 for this forged 383..
here are the mods.
Forged eagle 3.75 crank
Forged eagle 6 inch H beams
Forged Je -28CC pistons
LE 2 Heads
Custon ground cam 234/242 568/540 111las+2
Pro-gram Splayed 4 bolt mains
Oil Pump Moroso 22135
Oil Pan Moroso 20205
Lifters Comp 850-16
Rockers Comp 1305-16 (1.6, 7/16 Stud, NSA)
Rocker studs ARP 134-7103
Head studs ARP 134-4001
Valve Spring Locators CC-4705-16
Valve Spring Locks CC-613-16
Valve Spring Retainers CC-795-16
Valve Springs PAC 1518
Pushrods Lukovich Hardned
Guide Plate Iksy
Valves Manley 2.00 (11500-8) & 1.56 (11501-8)
Electric Water Pump MEZ-WP118HD
Injectors SVO 36lbs
compression 9.75:1
I plan to drop it a bit and boost it as well.
It put down close to 400RWHP and 420RWTQ N/A and needs some more tuning
So here are all the pics...I will post more as the work continues.
Today I got the rad in, and took out some more un-needed things.
Still have alot of work left.
-1 3/4 Long tubes
-Drive shaft
-Drop the tranny Pan
-power steering
-plugs
and other small goodies
here are the mods.
LE 2 Heads
Lifters Comp 850-16
Guide Plate Iksy
Injectors SVO 36lbs
compression 9.75:1
-1 3/4 Long tubes
-Drive shaft
-power steering
-plugs
oh Ya, It took a total of 5 hours to get the 355 out and the 383 in
Also the motor was in a 97 WS6 and went 12.0 N/A. And im going to be spraying it
. Also my 3rd gen weighs about 300lbs less
So when I spray I am hoping for a high 10 second pass
Jay
.Also the motor was in a 97 WS6 and went 12.0 N/A. And im going to be spraying it
Jay
Yeaa I cant wait. I just got all my fluids....freakin 8 quarts of Royal Purple 15-40 is pricey OMG (canada pfff). So 155 bucks in fluids today(oil trany and coolant). Tomorrow it should be ready to run Other than headers and a Y. My Long tubes will be in on tuesday
And I got my 4th Gen wheels with Brand new M/T DRs
...Had to get 4th gen offset for my Moser 12 bolt
I shall update the thread tomorrow.
Jay
.And I got my 4th Gen wheels with Brand new M/T DRs
...Had to get 4th gen offset for my Moser 12 boltI shall update the thread tomorrow.
Jay
carguyshu
Jan 22, 2017 11:19 AM
Henson071
May 4, 2015 12:23 PM
