Pics of engine bay without A/C and power steering.
to delete the power steering and the A/C you will need to get a Alt. bracket from www.madmanandcoracing.com.
Scott
Scott
Re: Pics of engine bay without A/C and power steering.
Dont look at the dirt or mess, but my pic shows the basic layout, after madman relocation bracket.
alt relocated
alt relocated
it really opens up the engine bay, thats for sure. but living in texas, i can't afford to lose my a/c. even though, i have another vehicle, i still can't stand sweating my butt off in the Z. i wish i could though.
I feel its relalively easy to remove all the parts needed. It will take some patients though as your removing alot of parts. If you're planning on keeping your PS rack, you can run lines directly to your resivour and run it. I wouldn't recommend running a line from one side to the other as the rack can't bleed itself this way. Plugging each side off isn't a good idea either as pressures can't be equalized within the internal seals which can lead to the internal seals failing. This would mean that the PS rack would have to be rebuilt if you ran PS again or wanted to sell the rack at a later date.
Attaching the bracket on and setting up the alternator after all is said and done takes about 20 minutes. Your going to find out running your plug wires are VERY easy now
Hope this helps
Steve
Hope this helps
Steve
Not to bad with Skinnys. You dont notice it much at all during most driving. Backing in and out of parking spaces are the worst. Just have to muscle it a bit and try to turn the wheels when the car is rolling a little
Now with 245 or 255s, I imagine you'd have you're work cutout for you.
And Steve's right - plug changes are so much easier now.
Originally posted by 95_RipperZ
How hard is the car to steer without the power steering? That is one open engine bay.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
formula218
Dec 2, 2014 04:27 PM
