Pick up Tube for the Moroso Race Oil Pump
Need a part number for a pick up tube to use with the moroso 710-22100 racing oil pump. Also will the gm white spring work with that pump as well?
Thanks!
Marcin
Thanks!
Marcin
Re: Pick up Tube for the Moroso Race Oil Pump
called summit and jegs and they both told me to use pick up part number 24212. I called moroso and they said that they do not make a pick up for a lt1, since the stock lt1 oil pan is nothing like a stock SBC oil pan....any thruth to that?
thanks
thanks
Well, it's either 5/8" or 3/4" tube pickup, and that pump uses 5/8". Stock pickup for 93-94 is 5/8". The pickup that was recommended is for a 7.5" deep pan so it wont work on your stock pan.
Early LT1's did come stock with 5/8", and far as I know no stock LT1 came with a HV pump.
Doug Harden
29
Jul 30, 2003 07:05 AM
