pic of something broken on my LT1, what is it??
Old Oct 24, 2004 | 11:37 AM
Hawk's Avatar
I was taking out my PCM to get it programmed, and I noticed a line that was broken off at the fitting. I possibly could have broken it when I was taking out the pcm since the line was in the way, not sure though. Anyway, here are 2 pictures of what is broken, can someone tell me what this is, and to fix it what do I need to buy exactly, or can i just epoxy it back together??
Thanks for any help.
Brian
http://home.comcast.net/~bhawalka/broken1.jpg
http://home.comcast.net/~bhawalka/broken2.jpg
Old Oct 24, 2004 | 11:47 AM
My Iroc Z28's Avatar
Re: pic of something broken on my LT1, what is it??
Brian
that looks like the vacuum for the heater & a/c door flap, to verify that turn on the heat then turn it off with the car running and see if you hear the door close and a hissing sound..
Old Oct 24, 2004 | 01:27 PM
3gc's Avatar
3gc
That looks like a check valve. I'd remove it, go to the dealer and get a new one, can't be more then a few bucks. Then pull the broken part out of the 90* vaccum fitting and plug it back in.
Old Oct 24, 2004 | 02:00 PM
chad_g69's Avatar
its is a vacuum check valve - mine was broken also - controls where the heat/vent/ac will blow (feel, defrost, main vents) cost like $3 at autozone...
Old Oct 24, 2004 | 02:15 PM
Ryan94ZA4's Avatar
Yep. One line goes into the car for the HVAC controls, one goes to the intake manifold, and the other goes to the vacuum reserve canister on the passenger frame rail.
Ryan
Old Oct 24, 2004 | 02:18 PM
Jeffs94Z28's Avatar
so thats why my heat doesn't work correctly...thanks
Old Oct 24, 2004 | 02:33 PM
Hawk's Avatar
thanks for the quick responses. i'll go ahead and get new valve now, no big deal
HectorM52
Jun 23, 2016 08:42 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
