Pic inside...which has water pump shaft bearing installed right?
I got a new wp gear assembly today and the new one has the bearings pressed on alot further than the one I removed did.
Maybe when I removed it, the bearings slid to the end of the shaft??
I noticed there's a lip on the shaft and the new one has the bearing pressed all the way to the lip..is that where it should be?
Here's a pic of both of them.
