View Poll Results: If your engine out would you put a gear drive in or keep it stock?
Yes - Put in a gear drive
14.29%
No - Keep stock timing chain
85.71%
Voters: 7. You may not vote on this poll
Pete Jackson Vs. Stock Timing Chain
Old Jan 1, 2005 | 08:15 PM
(White Lightning)'s Avatar
Exclamation Pete Jackson Vs. Stock Timing Chain
I hear from people all the time, that you can do this and have talked to people that have done this but... If It was up to you would and you had your engine out of the car putting in the Hot Cam and port and polishing you heads and intake would you for the sound put in a pete jackson gear drive or keep it stock? Yes or No, If it was an easy switch would you do it???
YES OR NO
Old Jan 1, 2005 | 08:49 PM
Robs97Z28's Avatar
Re: Pete Jackson Vs. Stock Timing Chain
I would go with ED LT4 timing set from Jason for $205. There would be no major mods and everything would bolt up.
Old Jan 2, 2005 | 07:50 AM
no one is voting?
Old Jan 2, 2005 | 09:11 AM
95LT1Z28's Avatar
Go with the Cloyes True double roller $80 and get the CSI electric water pump. To me that is the only way to go. Gear drive would be cool, but as others have mentioned in the past knock sensors or more prone to give false knock with the extra noise from a gear driven timing set and that is something I would not want to mess with. Just my $.02.
Jeff
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
