Pesky Oil Leak
Old Jan 23, 2006 | 08:02 PM
theroad64's Avatar
Pesky Oil Leak
I have an RPM dependent oil leak somewhere on the front of my motor. at WOT it gets oil on the serpentine and slings it about the engine bay...not much, but enough to be annoying as ****. WOT aggravates this problem VERY badly. I'm thinking timing chain cover but could it be oil pan? I'm doing poly motor mounts this weekend and I'm going to replace the pan gasket as well as valve cover gaskets, hopefully this will solve it. If not...well I guess I gotta pull the opti.
Old Jan 23, 2006 | 08:15 PM
bowtiethunder's Avatar
Re: Pesky Oil Leak
sure its oil? maybe its power steering fluid.
Old Jan 24, 2006 | 05:10 AM
theroad64's Avatar
Re: Pesky Oil Leak
Nope, oil it is.
Old Jan 24, 2006 | 03:08 PM
Re: Pesky Oil Leak
I would guess that its coming from the opti seal in timing chain cover if its oil. My car once leaked at the opti seal and front of the engine was nasty. I just don't see how oil could sling from a oil pan leak.
Old Jan 24, 2006 | 06:05 PM
slowZ's Avatar
Re: Pesky Oil Leak
check the water pump drive seal. mine went out after changing the w/p. after i noticed the seal was bad i replaced it. that seal is some what stubborn to get in right, and like bowtiethunder said the opti seal could be the culprit too.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
