Perimeter bolt valve cover conversion
Old Dec 20, 2007 | 10:05 AM
lt1nova's Avatar
Somewhere in looking at head porting services I found one that will do a perimeter valve cover conversion as well. Has anyone else run across this? Who are some porters other than Lloyd Elliott as I don't see it on his site.
Old Dec 26, 2007 | 06:03 PM
lt1nova's Avatar
I saw some heads on Advanced Inductions website that had them so maybe that's what I saw the first time. I emailed them to see if they will do just that service.
Old Dec 26, 2007 | 06:28 PM
dangalla's Avatar
do you have a good reason to waste money on that
Old Dec 27, 2007 | 09:32 AM
The Engineer's Avatar
You can also buy an adapter plate that will do the conversion. Or like my AFR heads which go both ways (center-bolt, or old-style SBC 4-bolts).
WD
Old Dec 27, 2007 | 12:25 PM
Bersaglieri's Avatar
It's in a Nova and the centers probably dont match the 'era'. For me it would be a who cares lets save that money for something else.
-Dustin-
Old Dec 27, 2007 | 04:31 PM
Projectz28's Avatar
Moderator
The conversion plates usually are not that good. They will also limit spring and rocker are choices. you can not use a big spring with a conversion plate.
Converting the heads really isnt a big deal. Just need to add a little metal where the bolt hole are. Mill it flat, drill and tap the hole and bolt on a set of perimiter covers. Any head porter should be able to do it, or any fabrication/welding machine shop can do it with ease.
Old Dec 27, 2007 | 05:24 PM
Boosted_Z28's Avatar
I never checked on a set of stock LT-1 heads, but on these set of Trickflow heads, I was able to just drill and tap them for this set of perimeter valve covers:
Old Dec 27, 2007 | 06:16 PM
White Lightning's Avatar
good god thats sexy
Old Dec 27, 2007 | 06:19 PM
MeanGreen97Z's Avatar
Originally Posted by sitnhi
good god thats sexy
I just creamed my panties....
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
