Perimeter bolt valve cover conversion
Somewhere in looking at head porting services I found one that will do a perimeter valve cover conversion as well. Has anyone else run across this? Who are some porters other than Lloyd Elliott as I don't see it on his site.
The conversion plates usually are not that good. They will also limit spring and rocker are choices. you can not use a big spring with a conversion plate.
Converting the heads really isnt a big deal. Just need to add a little metal where the bolt hole are. Mill it flat, drill and tap the hole and bolt on a set of perimiter covers. Any head porter should be able to do it, or any fabrication/welding machine shop can do it with ease.
