Perf and Handling Upgrades
Old Mar 22, 2004 | 09:09 AM
a600sprintracer's Avatar
Just looking for some help on where to get started so if you could help me please give me a list of performance and handling upgrades from start to finish. Looking for good to great handling and low 12s without nos or supercharger but driveable (if possible). Thanks.
Old Mar 22, 2004 | 09:12 AM
Hyperspeed97z28's Avatar
Get some Subframe Connectors first...
They will tighten up the car big time !!!
Old Mar 22, 2004 | 09:31 AM
1msfyter's Avatar
I have a 35mm front swaybar 24mm rear. LCA's, relocators, subframes, strut tower brace, sticky goodyear F-1's 18rear and 17 front tires
Old Mar 22, 2004 | 09:35 AM
Bow94z's Avatar
my car has 122,000 on it. steering wheel begins to shake while crusing at like 60-70mph . what are some thing's to change up front there
how much improvement do lower control arms give ya?
Old Mar 22, 2004 | 09:52 AM
93ZM6Tally's Avatar
Subframes stiffen up the frame for handling and won't help much with what you're talking about, but definitely improve overall handling and how "tight" the car feels. I would begin concentration on your front end. Start with the basics, ball joints, and maybe a poly bushing kit and larger front sway bar if you're looking to improve above stock. Shocks are also very important and you have a wide ranges of choices there depending upon what you're looking for. Also don't forget about tire balancing and front end alignment which could be contributing to your vibration. You also might want to inspect your rag joint.
I did the above, a poly bushing kit, front shocks, (went with Koni SA's), and a 35mm front sway and replaced all of my springs with SLP take offs which are very reasonable. Had it aligned after that and was very impressed with the improved handling and "tightness" of the car. I also did weld in sub frames and put poly bushings in the rear LCA's. I wouldn't recommend the poly LCA option, I would just go ahead and buy some aftermarket LCA's, especially if you're interested in doing any drag racing. Some LCA's will bind under hard cornering so if you're interested in Auto Cross or more street handling boxed LCA's may not be the way to go. I also put new Bilstein shocks in the rear as I was looking for more road handling at the time. I'm now into straight line performance so if I had it to do over I'd probably have gone with QA1's. At any rate decide now what you want your car to do and it will help with the choices that you make in your suspension.
Good luck.
Old Mar 22, 2004 | 10:26 AM
Red96Lt1's Avatar
I think sub frames would help alot. And LCA's don't take any lateral load.
Old Mar 22, 2004 | 10:27 AM
Red96Lt1's Avatar
As for performance a CAI should be your first mod. Its the best bang for the buck.
Old Mar 22, 2004 | 09:14 PM
Thanks for all the handling anyone out there wanna help with performance?
Old Mar 22, 2004 | 09:21 PM
LS1_03's Avatar
Either get new tires, or get the current ones rebalanced. My car did the whole steering wheel shake thing until I got new tires.
Performance:
CAI
Catback
Gears
Old Mar 22, 2004 | 11:09 PM
Bow94z's Avatar
just put tires on it..still shakes a bit
Old Mar 22, 2004 | 11:20 PM
which 35mm front bar are you guys running ???
Old Mar 23, 2004 | 07:07 AM
Oh yea one helpful bit of info when it comes to the performance upgrades please keep in mind the 94 Z has 132k miles on it so please tell me stuff that won't blow it up.......right away anyway
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
