people who know delteqs
Old May 10, 2004 | 08:29 AM
  #16
HOZZ4's Avatar
Our Bare Bones kit ($347.65) requires the following items:
4 coils and ignition module from Cadillac Northstar V8. (these items are generally called the "coilpack" when assembled)
Spark plug wires
For $42.50, you can purchase our custom 8mm double silicon wires for the radiator shroud mount setup. then, you would just need to get a used Northstar coilpack. So, you would be into the system for $390.15 plus the coilpack...
I am not sure if any aftermarket ignition wires work with our system. In all honesty, though, you will probably not find any aftermarket wires for under $70 that have double silicone wires AND silicone boots like ours...Most wires out there are silicone outer jacketed with cheap inner material. Ours are high temp silicone inside and out.
FYI - there is a guy on eBay selling new take-off coilpacks for $120. I have had a few customers buy coilpacks from him, so I think they should be good.
The MSD units designed for signle coil distributors (like Opti's) WILL NOT work with our system. If you need a rev limiter or timing retard, you need a DIS-4 from MSD, and the coil adapters that MSD makes for late-model GM coils.
Feel free to call us with any other ?'s!
Pete
Old May 10, 2004 | 08:37 AM
  #17
80TA's Avatar
Thanks for the info will likely just get your wires..What exact year northstars do you need to get the coilpacks from..thanks again..
Old May 10, 2004 | 08:53 AM
  #18
HOZZ4's Avatar
1994-1998 Caillac Northstar V8 and Olds Aurora V8 engines have the proper coilpack to use with our system. The Cadillac one generally comes with a nice aluminum bracket if you ask for it. It is a nice piece if you want to mount your coilpack in a place other than the radiator shroud or the valve cover...we;ve got those two covered with our brackets.
Pete
RX Speed Works
Oct 1, 2015 10:19 PM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
