People with single plane intakes inside
Old Aug 12, 2006 | 07:39 AM
  #16
engineermike's Avatar
Re: People with single plane intakes inside
Turbo6, there's an intake identical to that sitting at Thunder Racing right now - carbon fiber base and all. Is it yours?
Mike
Old Aug 12, 2006 | 07:40 AM
  #17
Originally Posted by Schurters LT1
I. . .d the custom elbow to fit under the hood.....well i will have to look into that...
Trust me, it will fit under a stock Z28 hood with a custom elbow.
Old Aug 12, 2006 | 10:42 AM
  #18
Turbo6's Avatar
Mike,
Yep, that is my intake. It's supposed to be installed on the car by the end of next week so hopefully it isn't still sitting there. We ran into some issues with fitment. BRE (who made the intake) felt comfortable only running the outside 8 bolts since you can't redrill the intake for the LTx bolt pattern due to runner placement. I didn't really feel comfortable with how it would seal so we ended up modifying the heads to accept the SBC bolt pattern. I can't wait to see the dyno numbers when its finished!
Old Aug 13, 2006 | 12:26 PM
  #19
Schurters LT1's Avatar
Hey Mike do you no anuone that can do this custom elbow ? i have been talking to http://www.intakeelbows.com/ and he thinks he can do it....
Would you be will to sell your intake ?
Old Aug 16, 2006 | 12:58 PM
  #20
SLeePer350's Avatar
Mildly considering this swap as well to mount to the 355 when it comes in. Regardless of fitment how did everyone decide on their respective manifold? super vic, etc - pros and cons? hp gains?
how is the service at intakeeblows.com? i just sent them an email this afternoon to see who they can help me with some stuff.
thanks guys
Old Aug 19, 2006 | 06:02 PM
  #21
Originally Posted by Turbo6
Mike,
That's funny. Shane was just showing me how he drilled and tapped the 4 middle bolt holes. . . We discussed for a bit the possibility of just going with the outside 8 since the Vortec 350's worked fine like that.
Old Aug 19, 2006 | 06:08 PM
  #22
Turbo6's Avatar
Well thanks for your contribution. BRE seems to think it will be OK but I never liked the idea. The real question is what kind of numbers will it make. I've never seen any back to back testing on an LT1 with a single plane so I'm looking forward to the results.
Old Aug 19, 2006 | 08:49 PM
  #23
I've started making my own. I started out with a 1/2" aluminum Holley carb spacer and an old LT1 intake. I cut the TB flange off the LT1 intake, keeping the MAP and cable brack mounts intact. The next step is to cut out the sheet metal needed to mate the 2 together.
You want to buy my Victor EFI or the ported LT4?
Mike
Old Aug 19, 2006 | 11:00 PM
  #24
I was asking about the EFI intake....but i think i might hold off for a bit.....
The 355 T-Trim set will be over 700rwhp the next time i go to the dyno and over 600rwtq as well, After i fig out some of the tuning with the Gen 7...
I didn't think the car would make this kinda power....
Old Aug 19, 2006 | 11:40 PM
  #25
The 355 T-Trim set will be over 700rwhp the next time i go to the dyno and over 600rwtq as well, . ..I didn't think the car would make this kinda power....
You 6-speed guys make me sick.
My similar combo only made 550 rwhp through a TH350/loose converter.
383 cid, 8.3/1
AFR 210 Race Readies
224/236-114 cam
Vortech T-trim 6.66/2.75 for 13 psi
Vortech Aftercooler
Though, it did run 10.40 at 133 at full street weight plus some.
Mike
Old Aug 20, 2006 | 12:08 AM
  #26
383 cid, 8.3/1
224/236-114 cam
Vortech Aftercooler
Mike
LOL Hey it's only a number ..the ET is the one that counts
Old Sep 15, 2006 | 02:56 AM
  #27
blown383's Avatar
Subscrbing in hopes of finding a single plane that ready to bolt on.
-B
Old Sep 15, 2006 | 09:08 AM
  #28
RealQuick's Avatar
get some practice, I may need to call you next spring for question/tips. I just received my Gen 7, dual sync dizzy, msd6al and coil last night!!!
Old Sep 15, 2006 | 10:19 AM
  #29
ksmyss's Avatar
what about something like this?
http://www.sullivanperformance.com/Y.../tbadapter.htm
Old Sep 15, 2006 | 02:27 PM
  #30
GetaZforgetGT's Avatar
Originally Posted by ksmyss
This thread has a lot of info on the above adapter.
http://web.camaross.com/forums/showt...light=sullivan
