People with AI and LE heads...
Re: People with AI and LE heads...
Either guy's heads will likely get you where you want to go. Just call em' up, compare the prices and make a decision.
You can't base your decision on who's running the better times because there are far too many more important variables at work than "who's" cylinder heads are on top of the engine.
Good luck.
-Mindgame
Good luck.
-Mindgame
As Mindgame said.... compare the results of what people have to the prices and go from there.
Drag times are a function of car setup. You could have a F-body setup just to drag race with a stock motor run faster than a head cam car that wasn't meant to be drag raced...
Bret
Bret
The reason I made the post is to actually get some results everyone says great things about both but I never see any track times just dyno numbers, which I guess should be enough results but I can't make my mind up.
Both will give you great results, to be honest, as long as your willing to spend the money/put in the work to make sure the REST of the car compliments your heads and cam. Call up both guys, and talk to them. See which one you feel more comfortable with. FWIW, I have never heard someone with a legitimate bitch about these two guys. They're both stand up and stand by their work.
On another note, be careful with threads like this, they tend to turn to nothing more than a flame war between guys that are loyal customers of one or the other. G/L
Just read one of those threads
Times in sig, 3000 stall, 3.73's in 10 bolt, et streets with the first setup, in horrible weather(2350da) and then a 3600 stall with the 383 but only got 2 passes with it.
LE heads with LE2 cam. 12.11@116 with a 1.898 60 foot (wet track and poor tuning). Car pulls 1.67 60 foots so I should be in the mid 11s with better tuning this spring.
RX Speed Works
Oct 1, 2015 10:19 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
