people with afr 210cc heads on stock bottom end inside
Originally posted by mastrdrver
. . .I still be hard headed about this. I would love to be proven wrong, but I still don't see port velocity, which is very important on the street, being very good with those heads. I still say it will take some rpms to make your power. I'm not really a person that likes to have to turn the engine to 7000rpms to shift.
Peak power came at 5,800 and I shifted at 6,200 rpm. Not exactly 7000 rpm, huh?
A 210 head is not as big as you think.
Mike
Originally posted by aggiez28
ken what heads ya gonna be using? your not keeping the lt1 block are you... ive been thinking...if ya want to make huge power, no point in sticking with the lt1 unless you want to for soem spacific reason
brook
brook
Yes i will be using the stock LT1 shortblock. Reason why = $. I dont have the money to redo the shortblock to what i'd like, and if i did redo the bottom end id use custom pistons and use completely difrent heads like 18* or canted valve, etc. So the snowball effect is rediculous and i have to draw the line somewhere
masterdrver
i took to a guy here in town,it was the first car he did on it not sure if its totally accurate,the clutch was slippin before we dynoed it,we finished it on the dyno,should have put in a new with the rebiuld never noticed a problem before though.after the new clutch i amtaking it to somebody with exp on dynos.
Arn't the Brodix -10s 18* heads?
I guess what should be asked is, does anyone have any track times with these big headed, daily driven, stock bottoms engines? As dyno #s are just that, but track times are what matter.
My point about the ported heads verse the AFR 210s is this: IF you have two heads that flow close to each other, the smaller head should, in theory, make more power bcuz of better port velocity. This is why I say go with the ported stockers. Even on a big engine like 383/396 they should make 430rwhp with atleast 400rwtq with a good cam.
