pcv valve 90 degrees elbow
Old Jan 13, 2008 | 03:02 AM
Wims97T/A's Avatar
I have noticed that the 90 degrees elbow on my pcv valve is a litlle bit broken so it is leak now after examining it.
It is different as showed on the photo on shbox website.(which is straight "hose" and the metal tubing is 90 degrees)
it is a '97 T/A and it is equiped with traction control.
Just looking for a pn number right now.
I ve ordered a part overhere at a local usa part importer but he came up with a hose which did no looking near to the original.
Old Jan 13, 2008 | 09:35 AM
GM PART # 12551389 for the right angle hose going into the front of the intake manifold and GM PART # 12556257 for the pipe assy (no other hose parts listed). It is listed the same for all 95-97s.
Old Jan 13, 2008 | 09:37 AM
Are you refering to this connection?
http://shbox.com/1/pcv.jpg
http://shbox.com/1/pcv_pipe.jpg
Has you PCV system been altered due to the use of the Paxton supercharger?
Old Jan 13, 2008 | 10:54 AM
Wims97T/A's Avatar
Shoebox: thanks for the pn numbers.
Injuneer: thanks ,yes picture 1 that is the connection i am refering to,and it is still stock.
I will take some pic's tommorow ,i made a sort of new elbow,but that is not realy working fine.
Otherwise i am going to order the part numbers Shoebox mentioned and
going that route.
Old Jan 13, 2008 | 01:28 PM
nb 96 z's Avatar
I know what your talking about. No one sells just the elbow. For some reason the pics that shoebox and injuneer posted show the straight hose coming off the metal elbow. My stock hose coming off the metal elbow was a 90* bend. The part #12336257 that shoebox listed is the entire pcv metal pipe including the the hoses to the front of the intake manifold and the pcv valve. However, pic 2 that injuneer posted shows the metal pipe curve toward the intake manifold with a staight hose... the one that I got from the dealership ($11 or so) the metal pipe is curved up (like it is twisted to the right if you compare it to picture 2) and then there is a 90* hose coming off the end.
Old Jan 14, 2008 | 11:14 AM
The pictures I linked are the ones from Shoebox's site.
Old Jan 19, 2008 | 12:53 PM
Wims97T/A's Avatar
well it took some time but here are the pictures.
Old Jan 19, 2008 | 12:57 PM
ssbowtie1's Avatar
How funny. I was about to make a post asking for that part number myself. I have a 96 TA, so apparently our years use a different connection. I just wrapped electrical tape around the bend for now. I'll let you know if I find the right part number or a solution.
Old Jan 19, 2008 | 01:11 PM
I already posted the only part number I find in the book for the pipe. Are you saying yours looks like his and not like mine?
Old Jan 19, 2008 | 01:14 PM
ssbowtie1's Avatar
Yup, its a 90 degree rubber bend like the pic shown above.
Old Jan 19, 2008 | 02:41 PM
ssbowtie1's Avatar
Must be a 96-97 option. I looked in my 95 service manual and it had the same setup shoebox listed.
Old Jan 20, 2008 | 02:08 PM
nb 96 z's Avatar
Yup. That's exactly how mine is and I've got a '96. Off topic here but does anyone know the part number for the pcv grommet? The rubber grommet that goes into the right side of the intake manifold where the pcv valve goes in to. Thanks.
Old Jan 20, 2008 | 02:43 PM
GM PART # 10240678 as listed on my part numbers page.
Old Jan 28, 2008 | 12:30 PM
Wims97T/A's Avatar
I have ordered the pn number shoebox mentioned(thanks btw)
Look what i picked up today at a local dealership overhere:
unbelievable in my opinion.
Old Jan 28, 2008 | 12:35 PM
ssbowtie1's Avatar
Nice! What was the # exactly? How much did it cost?
