Pcv valve ??
Old Apr 30, 2006 | 09:19 AM
WhiteCamaro88's Avatar
Pcv valve ??
The pcv on my 94z goes from the tb to the top of the valve cover on the pass side correct ? the hose that goes from the tb to the valve cover has a tear in it what it is called ?? since its not the pcv valve it self ? if u get a new pcv valve does the hose come with it ???
any part #'s or anything would also help
Old Apr 30, 2006 | 11:08 AM
94zrag's Avatar
Re: Pcv valve ??
The PCV valve on your car is on the drivers side of the intake manifold. Look for a U-shaped hose and just pull on it, it should pop out. The hose going from the valve cover to the TB i'm pretty sure is just a vacuum line.
Old Apr 30, 2006 | 11:11 AM
94zrag's Avatar
Re: Pcv valve ??
Oh yeah, the part # for the pcv valve is 25095452.
Old Apr 30, 2006 | 02:29 PM
MeanGreen97Z's Avatar
Re: Pcv valve ??
He needs the part number for the hose....
Old Apr 30, 2006 | 02:33 PM
Honda Hunter's Avatar
Re: Pcv valve ??
Does oil ever enter the intake from the drivers side pcv hose?
Old Apr 30, 2006 | 05:27 PM
sbs's Avatar
sbs
Re: Pcv valve ??
That hose is part of the PCV system. According to this thread it's #10128365 :
http://web.camaross.com/forums/showt...tube+passenger
I happened to be searching for this recently. On the vette, it's a hard plastic tube with a small rubber hose joining it to the TB, and that hose was split. I was able to just use a piece of generic vacuum hose.
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
