Heads help
Old Apr 29, 2006 | 07:40 PM
rondav WS6's Avatar
Heads help
I am having a set of LE2 heads installed but between the valve and piston there is only .008 clearance but should be .080 without a gasket it is degreed right and has 0 back lash on the valves what could be the problem please help I bought the heads off Z28.com
Old Apr 30, 2006 | 07:09 AM
sssalah's Avatar
Re: Heads help
How are you measuring that distance?? If that is accurate you have all right to be worried.
Old Apr 30, 2006 | 10:18 AM
z28will's Avatar
Re: Heads help
get square off ur block both ends and mic. off that double chk heads also
Old Apr 30, 2006 | 05:38 PM
Joe B's Avatar
Re: Heads help
Yea, describe exactly how your going about checking valve to piston clearance.....that way one of us can see if something stands out easier......what cam?.....what LSA?.... and less importantly but im curious, it's lift?
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
