PCV Valve
Old Apr 10, 2006 | 07:03 PM
supercharged87's Avatar
PCV Valve
On a '94, where is the vacum source for the PCV valve supposed to come from? On mine it comes from the intake, right next to the PCV, but I seen another LT1 and it came from the throttle body.
Old Apr 10, 2006 | 07:36 PM
Mtrhds94Z's Avatar
Re: PCV Valve
94 has a U shaped hose on the drivers side of the intake manifold for the PCV that loops right back into the intake by the PCV valve..
95-7 have the PCV in the same place but the vacuum source is up front in the intake manifold just under the TB..
Old Apr 10, 2006 | 07:54 PM
hulettsz28's Avatar
Re: PCV Valve
any pics? i had a similar problem to this.
Old Apr 10, 2006 | 10:44 PM
Re: PCV Valve
What problem? Two different ways the PCV vacuum is routed was described. There's no problem with that.
Old Apr 11, 2006 | 07:15 AM
Re: PCV Valve
This is a 94 setup, U-shaped hose hiding under the brake booster hose:
http://www.injuneer.com/images/photo.../dOptivac1.jpg
Old Apr 11, 2006 | 08:28 PM
Re: PCV Valve
Okay, so mine is ran okay. Thanks alot for the help.
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
