pcv line
Old Jun 26, 2012 | 08:06 PM
94Z28LS1toLT1's Avatar
pcv line
Hey guys on my pcv hose the other end that inserts in the intake manifold the hose has a kink in it causing a annoying noise like squealing,i would like to kno what i can to make it
stop. my pcv rattles n there is vacuum too
Old Jun 26, 2012 | 08:12 PM
Lilatlboy6969's Avatar
Re: pcv line
order a new hose from gm... i forget the part number but im sure shoebox or someone else will have it soon for you. i had to replace mine a month or 2 ago so i know gm still has them floating around in their parts room
i work at a dealership so its quite simple for me to check on whats discontinued and what's not
Old Jun 26, 2012 | 08:19 PM
Re: pcv line
GM PART # 10128361 for the U shaped hose on 93-94s.
Old Jun 26, 2012 | 10:53 PM
Re: pcv line
First ? Why did u have to change your pcv hose/or what problems did it give u and the othet one.may i get the info from u on the rubber hose that that goes into the intake manifold if u kno if they have that part in stock still? And thank u n rob for the replies back it was fast
Old Jun 27, 2012 | 07:26 AM
Re: pcv line
The GM number is still good. The part should be available.
Old Jun 27, 2012 | 07:59 AM
Re: pcv line
i did a full tune up including optispark, plugs, wires and pcv valve and hoses and egr system.. so i went ahead and bought all the hoses that i could find to go with all the new parts.. i have to worry about emissions where i live so im hoping all these new parts will get me by until my car hits its good ol 25 years old then i wont have to worry about that bs anymore
Old Jun 27, 2012 | 09:18 PM
Re: pcv line
Hey guys thank u it turns out it was my pcv valve was clogged it had oil in it buy my oil isnt leaking anymore.but ill need to change the pcv valve i just cleaned it for now.and the pcv elbow hose is good.
Old Jun 27, 2012 | 11:07 PM
Re: pcv line
It rattled and it had vacuum, but it was clogged? And if you were able to clean it, why do you need to replace it?
KYWes
Jun 14, 2022 06:52 AM
HectorM52
Jul 30, 2017 11:46 AM
pimpen1024
Aug 19, 2015 08:36 PM
Fastbird93
Jul 11, 2015 04:37 PM
colts0455
Jul 8, 2015 12:21 AM
