PCV Hose
That isn't the PCV valve on top of the passenger side valve cover. Its just an empty plastic elbow.
The line that runs from the TB to the valve cover supplies filtered and MAF metered (at least in 94 and ups) air to the PCV system. It is pulled into the passenger side valve cover, through the crankcase and lifter valley, and out from under the intake manifold, through the PCV valve located on the drivers side of the intake, and then dumped back into the intake manifold to be burned.
For a reliable, closed PCV system, you need to leave all the parts in place.
Does it have anything to do with oil, 'cause its leaking oil onto the intake... The hose isnt snug on there, its just there, doesnt take much to pull it off...Im thinking that I need to just put a hose clamp on it and be done with it...
i know i have seen several cars with those breathers in the hole in the pass side valve cover. are there any negative affects of removing it and replacing it with a breather? i would like to get rid of the PCV system since it makes a mess on my valve cover and in the intake manifold.
Check your PCV valve. If its OK, pull the oil fill cap off when the engine is running and feel/listen for any air/vapor chugging out of the oil lfill pipe. That would indicate a ring problem.
I personally would not alter the stock system. It is required to remove harmful vapor from the crankcase, and in a healthy engine it works fine. 800HP and no breather on my engine...
The grommet in the valve cover dries up and needs to be replaced. The hose end on the TB cracks and comes loose. You can get a new grommet, and I use a small hose clamp on the TB end.
Its not really a lot of oil, I was just curious of the oil build up around all the hoses on the right side of the TB... I took off the oil cap and there really isnt a lot of air being pushed out. So I assume its okay. Guess I will just put a clamp on there and see what happens...
i used a clamp on my pass side PCV tube for awhile, then bought a new one from a dealer. Can't remember how much,maybe $20.
and don't do the breather, unless you don't mind smelling burnt oil all time.
i put on one of those breather caps on the oil fill port and smelled burning oil every time i drove the car so i took it off after about 5 days.
bought a flat cap GM oil fill cap and no smell anymore.
Air should flow from the TB to the valve cover, so there shouldn't be any oil getting to the TB.
Im thinking that Im the only one who has oil on the side of the TB and on the intank....
