PCMforless and wires or SLP CAI??
The tuning on the LT1 cars is actually quite aggressive already which is why you'll get little to no gain with tuning. You really do not need tuning until you do head and cam work. The wires can wait until the stock ones start to go or you do headers and want to route them over the valve covers. A cold air intake is your best guess as it's a guaranteed 10 to 15 RWHP increase.
I disagree about the stock tuning thing. I got tuning because of a gear change and was pleasantly surprised by the fact that the car ran better. I don't have a before dyno, but you don't see many cars putting down 277 rear wheel with a TB bypass, PCMforLeSS tuning, 160 stat, cai, 1LE DS and a borla 2.5" muffler (NOT catback). No real power makers there cept CAI and the tuning.
Still, get the CAI first. Don't bother with the 8.5" wires unless yours need to be replaced. I did mine and stuck with the stock wires anyways to reuse the routing clips and because i didn't think i'd see any gain at all. Check out the LT1 myths thread.
My car put down 279rwhp and 312rwtq with just the addition of a GM WS6 Ram Air setup w/K&N and a 3" cut-out. Nothing more. At that time, everything else was 100% stock right down to the wires, plugs, iron manifolds, 3.42s, and factory PCM tuning (OBD2). So, I have to disagree with you and say that stock tuning is fine for a MOSTLY stock motor. M6s always dyno higher because they are less parasitic on the motor. Add a set of long tubes, a cam, and or head/valve adjustments and tuning will be required for optimal performance.
Like the others, I'd say to go with CAI and skip PCM tuning until you've added some significant mods to your car. If it were me, I'd do CAI and a set of long tubes (Jet-Hot LTs are awesome!).
My $.02....
The 7 for the TB bypass is debateable because that saves HP as the car gets hot, not really when at low-normal temps. My other mods, 160 stat = 0 and the driveshaft maybe 2.
Notice i didn't recomend the tuning but rather the CAI first. I was just pointing out that the tuning DOES help and is not the 0 HP some claim.
Well i would have to disagree with the 5 hp for the cai. I don't have dyno #'s or anything. All i got is sotp. But i could tell a difference. Maybe its only 5 hp gain all around but more on the top end. Because that is where i feel it more. Also much better throttle response. If it was only 5 hp i don't think i would feel it. So imo it adds around 7-10.
