Pcm4less
Old Feb 9, 2003 | 08:56 PM
Mr_Superman's Avatar
Pcm4less
I was just wondering if when you get pcm4less tuning if your computer could be programmed to do without o2 sensors....and if so how does the car run?
Old Feb 9, 2003 | 09:53 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
you cant run without o2 sensors
not half way decently anyway
Old Feb 9, 2003 | 09:58 PM
WheelmanZ28's Avatar
Re: Pcm4less
U can run without O2 sensors, but ur going to stay in closed loop the whole time.
I don't think programming will be worthwhile in anyway if ur having ur yanking ur O2s. It's gonna freak out ur PCM.
Old Feb 9, 2003 | 10:01 PM
HAHA thats what I thought just figured it could possibly be worth a try....glad to know just a thought that crossed my mind.
Old Feb 9, 2003 | 10:12 PM
Fear The Z's Avatar
Can they take a PCM from a V6 and program it for a V8?
Old Feb 9, 2003 | 10:15 PM
I'm pretty sure here is no possible way that would work.
Old Feb 9, 2003 | 10:18 PM
Fear The Z's Avatar
Why not? Anything is possible...
Old Feb 10, 2003 | 12:38 AM
Smokn '94 Z's Avatar
Arrow
LOL....
Old Feb 10, 2003 | 09:12 AM
Dr.Mudge's Avatar
Re: Re: Pcm4less
You will stay in open loop actually, which means you better do wideband tuning.
Old Feb 10, 2003 | 09:18 AM
madwolf's Avatar
To confirm the statement above, you CAN NOT program a v6 pcm to work with your car.
Old Feb 10, 2003 | 09:46 AM
Dr.Mudge's Avatar
Some PCMs are useable for 4/6/8, like the Typhoon, but I would imagine the Camaro stuff isn't. Just look for the appropriate PN V8 PCM and buy one.
Old Feb 10, 2003 | 09:48 AM
madwolf's Avatar
16188051 for the V8
Old Feb 10, 2003 | 09:59 AM
GREGG 97Z's Avatar
Re: Pcm4less
A lot of OBDII people (96-97) get their rear two O2's programmed out, they just monitor if your cats are working or not. The front two are the important ones that control your A/F ratio and effect engine function.
Old Feb 10, 2003 | 10:44 AM
millspec's Avatar
You can run without 02 sensors...but it isn't an ideal set-up. Lots of folks run speed density with a good sized blower. The reason for this is the MAF just can't keep up with all the air flow. GM shipped the Impala SS (export) with no cats or 02 sensors to places like Saudi. Not an ideal setup to run on the street and it takes some serious messing around with the PCM.
Old Feb 10, 2003 | 01:09 PM
Severous01's Avatar
spend the 40 bucks and go on ebay to get the o2 simms. then you will not need custom programming.
