Pcm4less
Re: Pcm4less
Originally posted by Mr_Superman
I was just wondering if when you get pcm4less tuning if your computer could be programmed to do without o2 sensors....and if so how does the car run?
I don't think programming will be worthwhile in anyway if ur having ur yanking ur O2s. It's gonna freak out ur PCM.
Re: Re: Pcm4less
Originally posted by WheelmanZ28
U can run without O2 sensors, but ur going to stay in closed loop the whole time.
Re: Pcm4less
You can run without 02 sensors...but it isn't an ideal set-up. Lots of folks run speed density with a good sized blower. The reason for this is the MAF just can't keep up with all the air flow. GM shipped the Impala SS (export) with no cats or 02 sensors to places like Saudi. Not an ideal setup to run on the street and it takes some serious messing around with the PCM.
