PCM Related?
Old Nov 14, 2005 | 05:58 PM
ChrisUlrich's Avatar
PCM Related?
Could the PCM be at fault only in closed loop? Could that part of the memory table be effected only? Runs great in open loop, but terrible in closed loop. Think it's PCM related as far as the PCM itself goes?
Old Nov 14, 2005 | 07:27 PM
Dave89IROC's Avatar
Re: PCM Related?
whats it doing?
Old Nov 14, 2005 | 07:34 PM
Re: PCM Related?
Once car reaches closed loop, it begins to stumble and fall on it's face. Will only stay on if I give it gas.
Old Nov 14, 2005 | 08:52 PM
turbo_Z's Avatar
Re: PCM Related?
Yes the problem is most likely PCM related but not anything physically wrong... you need to figure out whats going on when the car goes into closed loop. Basically look at the BLMs and see where most of them range so as to give you and idea what the PCM is doing.
Also, start by putting the stock throttle body back on. I see you have idle problems and keep screwing with the TPS. Take all that out of the equation by going back to the stock TB. A 58mm doesnt require any tune modifications where normal driving is concerned.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
fift5
11
Oct 1, 2015 10:31 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
