PCM Prob or Jesus playing tricks on me?
Old Sep 16, 2005 | 04:43 PM
ZKrazed's Avatar
Angry PCM Prob or Jesus playing tricks on me?
Alright here's what's goin on.....
Fully reinstalled my 383 from Golen Engine Service, brand new fully rebuilt T-56, new centerforce clutch, etc. The car will start and stay running at best 10 seconds, then the power to the fuel injectors is cut and the car dies. Sometimes it will restart right off the bat but will only run for half the time of it's original (5 seconds or less) other times it will just rotate and rotate and not ever start. If you wait a min or 2 it will fire right back up and then die like before. If you wait around 10 min or longer it will fire up and run the initial 10 seconds then die.
Here's what we have checked. The optispark is still firing, the computer is cutting off the fuel injectors. The ignition coil works, the crank sensor is fine, the grounds for the pcm are connected and are good. The spark plugs are fine and are ran correctly. The oil level sensor has been replaced, the coolant temp sensor has been replace, and the oil knock sensor (I think that is the correct name) has been replaced (ie. they are all new). Everything has been tested with mechanical instruments from my mechanic that is helping me with everything.
The only thing that has changed since the engine was repaired is the computer tune, that was done by Brian Herter of PCM4Less. All I had him do was delete 2 of the O2 sensors for they were throwing codes (if you need the actual code # let me know and I will provide it) and the Evap Purge Solenoid code. Will deleting any of these cause this problem? Brian suggested checking the security system (which is stock) for being faulty. I have yet to do so, hopefully we will have a scan tool to investigate that tonight. Failing that we are 99% certain we have a PCM problem.
Let me know what you folks think. Any help will be greatly appreciated. I have had everything connected for over a week she just won't stay running.
Old Sep 16, 2005 | 04:59 PM
neil350's Avatar
Re: PCM Prob or Jesus playing tricks on me?
This is the best thread title ever on here. Good luck
Old Sep 16, 2005 | 05:06 PM
What does Jesus have to do with it?
Sounds like a possible VATS problem. No deity involved.
Old Sep 16, 2005 | 05:51 PM
med_reject's Avatar
a bad ignition switch will cut fuel to the injectors, but usually this results in different symptoms. then there is vats
Old Sep 16, 2005 | 06:37 PM
Wildwill2855's Avatar
dude ive got the same problem, i contacted ion he said he mailed me a pcm out monday, it would take a while to start and it would run fine then shuts off in 5 seconds or so. when i find out ill be sure to inform you all.
Old Sep 17, 2005 | 01:33 AM
Dave '97 Z28 M6's Avatar
I agree!
Old Sep 17, 2005 | 10:18 AM
TedH's Avatar
You could try firing it up with a stock computer simply to test it. The tune won't be right but it should start and run with a stock PCM. If it doesn't, I agree with the VATS system.
Old Sep 17, 2005 | 10:22 AM
Silver's Avatar
Golen claims to provide a 'perfect' tune for their engines. Just curious, why didn't you use their tune? $$?
Old Sep 17, 2005 | 10:38 AM
when i got my pcm tuned what could had happend to "set off" i guess you can the vats system, i have it sounds like the same setup within reason of the other guy up there, deleted the o2's all that good stuff, just wondering what can set it off?
Old Sep 17, 2005 | 12:12 PM
ZKrazed's Avatar
Pardon my ignorance, but I have never seen the word or problem of VATS? What is that? Vehicle Anti-Theft System? Anyway to just disable it myself?
Oh yeah and Golen's "perfect" computer tuning comes from PCM4Less......You ship Chad your PCM and he just sends it directly to Brian or Alvin.
We checked the ignition module and it was working, the guy that tested said it was being a bit "squirelly" but nothin to warrant it being a faulty or bad unit.
And for checking the PCM by replacing it with a stock one, anyone live in or around Greensboro, NC with a 97 LT-1 OBDII computer?
Old Sep 17, 2005 | 02:07 PM
You are correct, VATS = Vehicle Anti-Theft System
It can be disabled and programmed-out. I'd suggest you contact Bryan and explain the problem you're having. He should be able to sort it out, or point you in the right direction.
Old Sep 17, 2005 | 02:22 PM
Honda Hunter's Avatar
So when you have an issue with the VATS the engine can still be started but will cut off later?
Old Sep 17, 2005 | 02:27 PM
Part of what VATS does is enable the fuel injectors. The engine may initially start with leftover fuel, but will quickly stall if the injectors are not enabled.
Old Sep 17, 2005 | 02:33 PM
Formula_driva's Avatar
I said that before I opened the thread
Old Sep 17, 2005 | 06:30 PM
what is done to fix this problem, im getting another pcm from ion , will that fix my problem if its the vats or no?
