PCM?- ODB2-ODB1 conversion Which pins are 21&22?
I am switching my car from ODB2 - ODB1. I have directions to wire pins 21 & 22 on the blue connector together then place a 2kohm resistor from these pins to ground.
This will trick the computer to see the knock sensors correctly.
Question is: How do know which pins are 21 & 22?
Go to Shoebox's website... he has tons of diagrams, photos, etc. Included the factory wiring diagrams, with a diagram that shows the pin numbering scheme on each connector.
If you haven't used Shoebox's Tech Website you're missing out on a valuable resource.
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
