PCM Location affect Knock?
Old Feb 24, 2005 | 09:35 PM
sweetride45's Avatar
I noticed that the PCM has a perforated Knock Module cover...if I were to relocate the PCM in the passenger compartment, would that affect it's knocking "Hearing" ability? I thought that's why it used a knock sensor on the block...I am also replacing the LT1 KM w/ a LT4...
Old Feb 24, 2005 | 09:52 PM
mmmchickenboy's Avatar
Re: PCM Location affect Knock?
if you moved the knock sensor to a different location in the block, then it might read differently. the LT4 knock module is less sensitive to detonation and other 'noises' than the LT1 module. the sensors should be the same though.
Old Feb 24, 2005 | 09:54 PM
I'm not talking about moving the Knock "sensor"...I'm talking about moving the location of the PCM to INSIDE the car...
Old Feb 24, 2005 | 09:59 PM
93turbo5oh's Avatar
its the sensor that pics up the knock, not the pcm itself. the pcm just interprates the information and pulls out timing.
Old Feb 24, 2005 | 10:02 PM
The knock module is simply an electronic filter circuit on a chip. It does not "hear" anything... it simply decides what signals from the knock sensor will be allowed to reach the PCM's knock retard logic. Relocating the PCM will not change anything.
Old Feb 24, 2005 | 10:06 PM
Sounds good...then the perforations are just for a breather... That'll work
HectorM52
Mar 15, 2015 10:45 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
dreamer1q
Aug 20, 2002 11:19 AM
