PCM for less.
Old Mar 15, 2004 | 09:48 PM
Elysian's Avatar
PCM for less.
I have a head / cam swap coming up here this weekend. Problem: I know I will be maxing out my stock injectors and with the cam I'm using (233/239 .569/.577 110lsa), the computer will definitely need tuning. What kind of experiences have people had with www.pcmforless.com ? Is the conversion to an OBD1 PCM really worth it? Is there anything involved in the conversion other than taking the OBD2 pcm out and plugging the OBD1 pcm in? Thanks in advance and would appreciate any input you might have.
Old Mar 15, 2004 | 10:10 PM
Ryan 97 Ram Air T/A's Avatar
I have been using PCMforLess for 2 years now and have been pleased with the performance. The tuning is money well spent. I'm not sure about the OBDI conversion, I left mine OBDII and just had some of the extra sensors turned off.
Hope this helps
Old Mar 15, 2004 | 10:13 PM
Lt1dtpower's Avatar
Thumbs up
I just used pcmforless and I'm glad I did. My car hasn't run this good since it was new. Throttle responce is great.
Old Mar 15, 2004 | 10:33 PM
Elysian's Avatar
Hope this helps
What kind of turn-around time did you end up with? Couple days? A week?
Old Mar 15, 2004 | 10:39 PM
Elysian's Avatar
PS: does PCM for less do any "part throttle" tuning? I assume that is a bigger issue with a bigger cam . . .
Old Mar 16, 2004 | 07:50 AM
texanmutt's Avatar
If you buy a cable (for obd1 PCM's), them you can have your program emailed to you. I think he also offers OBD2 to OBD1 conversions. It's worth it (if you dont have a high stall automatic) because OBD1 software is so much cheaper.
Old Mar 16, 2004 | 07:56 AM
Elysian's Avatar
I was rather concerned that the switch from OBD2 to OBD1 required that I eliminate my crank sensor. How big of a deal is that?
Old Mar 16, 2004 | 08:06 AM
texanmutt's Avatar
The sensor can stay there, it just wont be used. You dont need it, it's only there to detect misfires which you can do with you senses. The swap might be an issue if your state does obd2 scanning though.
Old Mar 16, 2004 | 12:26 PM
Elysian's Avatar
Talking
I live in Michigan. No emissions testing whatsoever. Longtubes w/ NO cats. Love it. Tree huggers are frickin' wrong about everything anyways - the same morons spouting about global warming today were warning about an ice age 20 years ago.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
