pcm ground stud size. (need to replace nut)
Old May 28, 2009 | 04:07 PM
SS44Camaro's Avatar
hate to start a thread for a simple question. but what size is the stud that the pcm ground connects to the block. i dont have the nut that came off it and need to get one, none of my bolts laying around the house fit so i'm guessing its metric. anyone know?
Old May 29, 2009 | 07:17 AM
01Z's Avatar
01Z
Everything else is SAE so I'm in doubt the nut you need is metric. Gently try a 5/16, 3/8 and maybe a 7/16". I think the stud is coarse thread so it would be 18, 16 or 14 respectively on the pitch. I'll go out and check later today and report back if no one gives you a definitive answer.
Old May 29, 2009 | 11:00 AM
SS44Camaro's Avatar
ok ill try again maybe i had a fine thread nut in the wrong spot or something. right now i have it on my starter bolt
Fatdog2
Feb 13, 2015 08:19 PM
Scottyboy
Feb 11, 2015 10:28 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
