PCM ground for fuel injectors
Old Jun 26, 2007 | 08:15 AM
ZL1modified's Avatar
where do they usually ground the blk/wht ground wire from the pcm for the injectors?
Old Jun 26, 2007 | 01:27 PM
IDAREU's Avatar
Are you refering to the car in your sig, the 97 z28? If so there should be a pink wire to all 8 injectors, that's 5v power. The other wire is a different color for each injector, Blk/wht should be the #5 injector. All grounds are made through the PCM that's how it triggers the injector to fire. Are you having a no start/ no injector pulse problem?
Old Jun 26, 2007 | 01:41 PM
yup.
my schematic calls out a blk/wht ground that goes from the pcm and is grounded on the body somewhere...
i found the tan/wht ground. i just don't know where the blk/wht ground is...
Old Jun 26, 2007 | 03:25 PM
The PCM gets it's grounds from the coil stud and the stud on the side of the block above the starter.
Old Jun 26, 2007 | 04:11 PM
thanks
Old Jun 26, 2007 | 04:45 PM
The injectors run at 12V. The pink wire comes directly from the underhood convenience box at +12V.
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
