PCM Adjusting Idle....
Old Jul 8, 2005 | 12:32 PM
Hawk350's Avatar
Is there a way to disable the PCM from adjusting the idle? I have adjusted teh TB idle and the damn pcm keeps the idle high...approx 1k-1200rpm. Is there a way to bypass this?
Old Jul 8, 2005 | 12:50 PM
Dave89IROC's Avatar
Re: PCM Adjusting Idle....
you did not adjust the throttle body idle screw, there isn't one
the screw on the T/B is the throttle stop screw, it should only be used for that purpose
if you idle keeps going high, find out why the pcm keeops raising it, since s stock is lower than that, something like 800RPM on the M6s IIRC
Old Jul 8, 2005 | 02:52 PM
Hawk350's Avatar
is there a way I can check this? I am not sure why this is happening....I just re-sealed the intake, adjusted the stop screw......car sat for 48hrs and not the idle is wacky....
Old Jul 8, 2005 | 02:55 PM
jsetzer's Avatar
intake leak can cause it to raise.
Mine is set at 650, and the IAC has been adjusted for my cam. If I push in the clutch it drops straight to 650, none of that reving crap like it used to do.
Check for leaks, then look into tuning. Put that screw back how you found it.
Old Jul 8, 2005 | 03:01 PM
Hawk350's Avatar
Intake is definately not leaking......it is sealed with that copper crap....laid it on thick, checked all, everything is tight, no oil leaking....anything else?
Old Jul 8, 2005 | 03:05 PM
jsetzer's Avatar
IAC (idle air controller) could be stuck/dirty. Its that little thing on the bottom of your throttle body held on by funny little screws. Pull it off and clean it out and the little hole in the throttle body real well with carb cleaner or something.
Old Jul 8, 2005 | 03:20 PM
Hawk350's Avatar
yes sir, thats what i will do when I get home. I cleaned the air idler before i sealed the intake but that didnt seem to help...so I will re-clean it and see if that helps. Thanks for all your help.
Old Jul 8, 2005 | 03:21 PM
Your signature indicates someone did "custom tuning" for your cam. Ask the person who did the custom tune what he set your idle at. If you want it lower, ask him if he can set it lower for you. Don't screw around with the throttle stop screw.
Old Jul 8, 2005 | 03:27 PM
jsetzer's Avatar
Most our gauges are 100-200rpm high on the reading. I have seen many tuners set the idle at 900-1000 for bigger cams. Could be a possiblity also.
Old Jul 8, 2005 | 03:57 PM
Hawk350's Avatar
I can recall that my ile was set to 800rpm....but I will recheck this again...
Old Jul 8, 2005 | 04:08 PM
BUBBA's Avatar
My idle was set at around 950 with my M-6 and small 210/224 cam. Since the tachs read high I usually see around 1100 or so.
Old Jul 8, 2005 | 04:30 PM
Hawk350's Avatar
should I be concerned that my idle is a bit high? I do have a pretty big cam installed.....
Old Jul 8, 2005 | 05:01 PM
BUBBA's Avatar
Actually, I believe that the idle should be high enough to not easily stall after initial start. On an A4, it needs to be not so high as to allow the car to move with your foot off the throttle or too low that it will run roughly or stall easily.
So the bigger the cam, the rougher the idle at low rpms. So obviously if you have a larger than stock cam, you will need a bit more rpm in order to achieve the same smooth idle (that's why a really big cam requires high rpm to stay running.)
So to answer your question, with that cam you may need 900-1000 rpm to run smoothly at idle and if your tach is reading 1100-1200 rpm, I say that you don't have much of a problem.
Your tuner would know about where your particular cam should idle. They may set it high enough to support the drag of the AC too. I have underdrives--don't know if I could idle any slower, and still be smooth, with the idle set less than the 950. JMHO
Old Jul 8, 2005 | 05:27 PM
Hawk350's Avatar
sounds good, I am going to be getting the car re-dyno tuned soon anyways....thanks for your assistance guys and thanks Bubba.
Aug 24, 2015 06:41 AM
realistyc
Jul 28, 2015 07:32 PM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
