Passenger side rocker panel
Anybody know where I can get a passenger side rocker panel? Can out of the mall today and noticed it was dented pretty bad
If not, anybody know how much this is to fix? It is the panel right under the door.
If not, anybody know how much this is to fix? It is the panel right under the door.Thanks
That panel is welded in and mostly that is body shop work. Im sure the dealer can get that piece for an arm and a leg. Just take it to a body shop and ask them how much for parts, how more directly how much for the panel. They should be able to help you, But unless your a body shop person, that is for the pros.UNLESS you are talking about the ground effect, then alot of places have them, dealer is around 250 for the ground effect. I think
Wilson
Jul 21, 2002 05:08 PM
