Passenger Side Motor Mount Ground
Old Jun 22, 2004 | 06:48 PM
Spinner's Avatar
There was a stud on my passenger side motor mount where it mounts to the engine block that held a HEAVY gauge wire, that I'm assuming is a ground wire. It goes directly into the engine harness, and I looked at shoebox's layout of the 1995 engine harness, and didn't see it in THAT harness. Is this a 1994 specific thing, can I just do away with the ground (the nut on the stud was frozen, I had to cut the ground wire to get it off), or are the coil grounds insufficient? Any insight is appreciated
EDIT: Looks like it's the battery cable ground. Guess that's important, and I need to recrimp it and reground it? Can I stick it somewhere other then the motor?
Old Jun 22, 2004 | 06:56 PM
Dave89IROC's Avatar
you pretty much need it going to the motor(it is the starter ground), anywhere on the motor will work though, block is best
Old Jun 22, 2004 | 07:09 PM
Spinner's Avatar
Figures. Any part #s for the stud and the nut? Mine are trashed. Shoebox?
Old Jun 22, 2004 | 07:25 PM
LWillmann's Avatar
The stud looks like #12555065. The nut isn't listed.
Old Jun 22, 2004 | 07:26 PM
simple's Avatar
pull it out and take it to the hardware store, match the threads and length
Old Jun 22, 2004 | 07:32 PM
Spinner's Avatar
Probably going to have to do just that unfortunately. Hard to find studs, may just go with a bolt, and ground to the bolt instead of a stud.
Old Jun 22, 2004 | 07:34 PM
Stud GM PART # 12555065
Nut-book shows GM PART # 14057004, but I don't see a listing at GMPD. 3/8-16 nut you can get somewhere else.
simple's Avatar
maybe put a couple small washers between the ground and the block, if using a bolt
Old Jun 22, 2004 | 07:38 PM
Spinner's Avatar
Excellent. I'll just pick up a nut and order that stud. I've got a few other misc. bolts to order while I'm at it, thanks
HectorM52
Jul 30, 2017 11:46 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
